I have a Dell 600m, which has a backup partition (about 4GB) which had really been bothering me. Basically I wanted the space. So I start up partition magic and delete the partition, that goes fine. Then I merge that partition with my main one and restart and get this message:
NTLDR is missing
Press Ctrl+Alt+Del to restart
This comes right after the starting screen - so the only options I have are enter bios, and choose start priority/run diagnostics. I made partition magic back up disks, but even after boot to prompt I can't access the hard drive. PM finds errors 1603 and 1520, but can't repair them. I ran dell diagnostics (which is a startup option) and they had no problem scanning the disks. But I can't run fdisk or chkdsk from the command prompt.
I tried a windows repair, but there was no option to repair or reinstall, a format is needed first. I would format, but I have some files on there with no backups. I'm going to get a laptop HD enclosure tomorrow and see if I can pull files off that way.
I've tried everything I can think of including running a sketchy program written by some guy I found on a random website. Nothing.
If anyone has any suggestions please post. Thanks
NTLDR is missing
