Opteron 185
A8N SLI SE
Corsair HX620w
2 gigs Corsair 3200 400 ddr
evga 8800 gts
I think it's a coincidence that I had just popped in my Opteron 185 from a single core 4000 about 20 minutes prior to a break-down. Everything was fine and dandy. Temp fine, played a game, fine. Then I was gently sliding the the side panel back on the case and poof, computer shuts down and attempt to restart. I get past the BIOS screen and then get this message on the screen where the component specs display, you know just before Windows starts. I get this message,"NTLDR IS MISSING, CTL ALT DEL to restart. It's my thought that I get this message just before i would hear the hard-drive starts it's spinning to start Windows. I replaced the hard-drive cable with a new one but that didn't work.
I'd gone through hell and back trying to get this system restored after my cpu busted a while back. Wrong diagnosis let me to change out a couple of motherboards (same chip-set) Finally, I get everything to together, with Windows seemingly running swell with my CPU replaced by Asus and now this? Possibly my rummaging around the case in the last couple months jostled the hard-drive one too many times?
Relating to the published advice listed below, do you think my hard-drive is gone. I mean the system crashed with Windows fully loaded while I was just gently putting the side panel on? But it's so weird that I had just replaced the CPU.
Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and/or NTDETECT.COM file.
Misconfiguration with the boot.ini file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
New hard disk drive being added.
Corrupt boot sector / master boot record.
Seriously corrupted version of Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard disk drive cable.
A8N SLI SE
Corsair HX620w
evga 8800 gts
