HELP! No HDMI!
hipsterdoofus
Ok, this may not be where this goes, but since some of you helped me set up my HTPC, I figured I would try here.
I have an Asus M3N78-EM motherboard. Initially, I did not have an HDTV hooked up, so instead of using onboard video, I put in an ATI card and used S-video. During that time, I purchased a small tv for my bedroom and at one time did hook it up via HDMI to my HTPC - had no problems.
Well, at that time, I was running Windows 7 RC I believe. A few weeks ago I reinstalled with full version of Windows 7 (64 bit this time). I bought an HDTV a couple nights ago and for the life of me cannot get HDMI to work. I've tried getting drivers from Asus, drivers from Nvidia - nothing works! the ATI card is still in the computer, but I wouldn't think that would cause a problem. Anyway, would LOVE any suggestions - messed with this twice now and can't get it to work. Thanks guys.
I would start by removing the ATI card from the computer. If you don't need it, take it out to rule out the possibility.
Ok, I will do that tonight. I hadn't done it yet because since it wasn't the weekend, I didn't want to do that and create a bigger mess - I have a little girl who would be upset if she didn't get to watch Curious George every morning, so after my nightly fights with this thing, I'm having to make sure it is functional again! :D
also make sure the TV is on and on the right input, THEN turn on the computer.
I'm pretty sure I've done this - but i'll double check that as well. I will admit that I've had both the S-video and HDMI plugged in at times just because I was testing didn't want to get windows loaded and have no video at all...
Now one of you guys is going to be on tonight so when this stuff doesn't work, I can ask you for more ideas, right? :D
Are you testing this on a machine that doesn't have windows loaded?
I don't have an HDMI capable video card in my machine, but I've read about them. I remember hearing that the HDMI video isn't available until the driver is fully loaded. I don't know if that was the first gen cards or for all of them, but that COULD be your problem...
Oh no - Windows is loaded and runs fine - S-Video works fine on the added in card I have - I guess I should also be trying the onboard VGA to see if it works - hadn't tried that - was just trying to get the onboard HDMI.
Demon, your suggestion worked - I took out the ATI card and the HDMI immediately started working!
One question for anyone else here using media player - The video seems great, but I noticed when I bring up the on screen stuff while playing back now (where the zoom, etc menus are) it all gets kind of stuttery. Anyone else ever experienced this? Never noticed it when using the video source.
