OK so I have never OC'd anything and today I decided I would fix the CAS of my RAM to what it was supposed to run at out of the.
Specs: OCZ Platinum DDR400 PC3200
ASUS A8N SLI Premium
AMD 64 X2 4600 (939)
Si I was reading that the RAM is supposed to run at CAS 2 not 2.5 so I went into the BIOS and changed it to 2.0 and changed the mhz to 400. Now my machiene will not post at all so I can change it back. I do not know what to do to flash the bios, especially since I did not build them with a floppy. This is a work box that i built for graphics.. bad idea to say the least.
Any suggestions
Thank you!
Any suggestions
Thank you!
