Been pulling my hair out for the last 4 hours trying to get this new setup working....
I bought a Gigabyte MA790X-UDP4 motherboard (b-grade) and an AMD phenom 720 tri-core black edition. Installed them in the case with no problems but I cannot get it to post! There is no bleeper, keyboard or VGA signal, though all fans and drives etc... are powering up fine and appear operational.
I am at a loss here... The RAM (2x2gb kingson DDR3 1333 matched pair) is brand new so it could be that? I have tried one chip at a time and have reseated the CPU / fan aswell. The internal bleeper is not even sounding when there is no VGA or ram install. I assume the board is DOA, but I need to make sure before I return it. Since it is B-grade it was a return but I was assured on the phone it was tested and working. Any ideas guys?
The only message I appear to be getting from anything is 4 consecutive blinks on the HD access light. These flashes also appear at the same time on a light on my graphics card PCB. Does that mean anything to you?
If it's not dead, the only thing I can think is that the CPU is not supported by the board without a BIOS flash. If that is the case though, surely it would POST anyway but run it at an incorrect speed?
What a stressful day it's been! If you have any ideas i'd love to hear them.
Dawson
Dawson
