Help! New build not posting
IndieSnob
I just received the following from Newegg.
Abit IP35
MSI 8500GT PCIE
Antec Earthwatts 430 Watt
CD2 E4500
G-Skill 1Gx2 DDR-800
When I have the 24pin ATX plugged into the board, along with the 4 pin 12V, the CPU fan will try to start to spin, but won't fully, and the GPU fan indeterminately spins up as well.
When I just have the 24 pin ATX plugged into the board the GPU fan spins continuously but the CPU fan won't spin at all.
I tried switching the the memory around in different slots, and took the board out of the case and tried to see if there was a short.
Unfortunately the only other computer I have around here is an old P4 with an Antec PS that only has a 20pin ATX connection.
I've built numerous other systems, but this is my first in a few years, so I'm naive to all of the new power regulations and the like.
Can anyone give me some troubleshooting tips?
Thanks!
Fans attempting to spin up then failing leads me to believe the PSU is the culprit.
I just tried out the new Earthwatts PSU on my old P4, and the system boots, so that leads me to believe the PSU is not the problem.
Now however I can't even get the new board to start spining up what so ever.
What do you think my next step should be?
Well, now the cpu fan and gpu fan both spin up, but it is not posting.
The cpu fan will spin up for a few seconds, then spin down, then re-spin up. I'm wondering if that's just part of the double-post issue that is known with the IP35 board.
Also odd that I don't get any post beeps out of my system.
