HELP:new build is this compatible
fudge2011
I am a first time builder:
so far I have complied these parts and need advise on if they are all compatible.
Case: cooler master sileo 500 with the power supply £60
Motherboard: Asus M4A87TD EVO (AMD 870) £62
CPU: AMD Phenom II X6 1090T (6 x 3.2 GHz) £162
cooler: arctic cooling freezer pro 13 £23
memory: Corsair 4GB XMS3 PC3-12800 1600MHz (1x4GB) £44
graphics: AMD Radeon 6850 HD £120
total: £471(reasonable price for a good pc whereby I can use eyefinity[two dvi and one dp port] i would say) what do you think. Oh! I think I will need the adapter dp to dvi to do that,,,say another £70 someone quoted on here. I would appreciate any input/advice/pointers, thanks :)
if there is anything else I have left out could someone please tell me. from my research all I need is these six things to build a pc as the motherboard will contain a wireless LAN.
Im also going to need a screwdriver, thermal paste.
You need some kind of optical disk and a hard drive. You may need some sata cables depending on what optical and hard drives you buy (OEM vs Retail). Do you need a card reader, mouse and keyboard? Do you really want your PC on wireless? If so, you need to get the antenna up high above the back of your PC to ensure best reception.
you need 2x2 gb memory to run in dual channel(or 2x4gb)must be matched sticks.
sorry I don't quite understand this. Can I not just have one 4GB stick?
How much wire will I need? As for the internal hard drive,,,is this a basic 3.5 inch that I can put in the native case? :confused:
I already have a mouse and keyboard but may want to use the original mouse and keyboard ports that are on old school mouses and keyboard. does the motherboard have to support this(ps/2) or is that a requirement of a separate pci card?.
in response to the LAN I am presuming, because my laptop picks up the signal of the modem connected to the wall y=by ethernet from upstairs, that the internal LAN of the motherboard will be able to do the same thing. Are you saying it wont and that I need someting different or just an extension of an antenna to this internal LAN receiver to make it as respnsive to the downstairs modem as possible. :confused:
In addition though, in the future I will be able to put an ethernet cable into the pc as I will be nearer the wall to receive the best broadband connection.(without the wireless modem). In anticipation of doing this do I need a motherboard with the ethernet port or can this be done with, another pci card? :confused:
and one last question :p do I need a firewire port? what is this for? thanks for replying and I hope this thread will get me on the right track to buying the right products soon, hopefully with no hassle and trepidation to the deadline of my current work tasks. :cool: ;)
You can run on one stick of 4 GB ram....but, if you do that it will run slower than 2 sticks of 2 GB ram. Mobo that runs in dual channel mode need two identical stick of ram for best performances. So, for dual channel you need 4GB = 2 x 2GB. Must be the exact same sticks, too.
Your motherboard (mobo) has 1Gb/s Ethernet port. Then you can connect to router. Wireless card can work, but PCs on the floor are lower to ground than laptops sitting on top of desk. So PC on wireless may not work too well. Will be fine with ethernet cable to router or modem.
Your mobo has pc2 connector for keyboard and mouse.
You don't necessarily need firewire port. If you have equipment that uses firewire (DV, etc.) then you want that. That mobo you have has usb 2.0, 3.0, and firewire. It also has esata port.
You need one sata cable for each hard disk and each optical drive that run on Sata. Hard drives are 3.5 inch....optical drives are 5.25 inch.
