My monitor displays "Video Cable Connected?" over a blank screen when I have my brand new Gigabyte HD6870 installed.
Specs:
Mobo: Gigabyte 890GPA-UDH3
Power: Seasonic 550 watts
RAM: 8 Gb (4x 2Gb) Gskill
CPU: Phenom II, X3 720 Black Edition
OS: Windows 7, Home Premium
The Mobo has an embedded HD4290 graphics chip. I was thinking a move to the HD6870 would show some improvement. The monitor ran fine through the mobo graphics.
I shut everything down and installed the new 6870. I plugged the monitor into the 6870. Power up, and it acts as if the monitor's input is not plugged in.
This is what I've tried:
Cycled power, cycled monitor power. No change.
Checked the 6870's fan: it's spinning.
Plugged the monitor into the mobo video output. Still dead ("Video Cable Connected?").
Swapped out a new monitor. All the same. (It's not the monitor.)
Next, I took out the 6870 and reconnected the original monitor to the mobo video. All is good. (Well, as good as it gets when your new 6870 is sitting on the floor and you're stuck with mobo graphics.)
Any help for me out there? What else can I do to troubleshoot?
Thanks!
Specs:
Thanks!
