Help NEEDED!
At first, my old computer and my wireless laptop can both get online. However after installing my new computer, the laptop is only sending packets and not receiving any packets, so it couldn't go online. Do you guys have a solution to this problem?
what else do you have?
a router?
was your old computer connecting with a wire or wirelessly? how about your new one?
the laptop, if oyu have a router, should have nothing to do with the other comptuer..
does the "new computer" go online? how? through a router?
The new computer is directly connected to the router. The laptop just won't receive any thing while it keeps sending. Old computer was directly connected also
this problem i have also how do you get into the network router settings to check the ips and stuff?
Yea, but how come it used to work fine with the old computer. What can i do to make the laptop be able to connect to the router wirelessly again?
