I am currently using a pc with the following specs:
Amd X2 3800+
MSI 7800 GT
Asus Mb that comes in that silvery box with the purple writing on it..=P...its new...i can't recall its exact model number...
anway....my hardware is housed in Asus Vento 3600 casing which is too big....
i have currently getting temps of 38 - 40 C.....when its idle....
I was thinking of getting some regular casing*smaller* and modding it up...
would i be able to achieve lower temps simply by air cooling and blow holes or would i need to do more?
Thanks for your help!
