help needed with sceptre 22
xgambetx
hey everyone i need some help with this monitor i recently got about a week ago...
http://www.newegg.com/Product/Product.aspx?Item=N82E16824112009
ok i read on the reviews many people have their DVI cable lose signal/wont work within like 6 months or so
i dont have any dvi cable at the moment but what i have been trying to do is use a vga to dvi cable and connect to the dvi slot but nothing ever shows up it just switches back to vga within like 3 seconds so i was wondering am i supposed to do something before i switch it or did i get an DOA dvi slot?
My mom has that same monitor I'll try to do the same thing and see what happens, but that will be l8r today.
Or just call tech support
Doubt it.
I have a Sceptre X20G-NagaIII and the DVI port died on the 8th month of operation. Oh well. I was also planning on getting that same monitor you're talking about because Sceptre monitors are solid, just that their DVI ports aren't.
Did you mean using a VGA cable & using the DVI to VGA converter?
I tried it and it worked fine with a dvi and vga so it must be your monitor.
try to RMA it if its still under warranty *shrug*
wow... well this really sux...
well i guess im just gona try to get a DVI cable see if that might work or something if not.. well gona have to RMA it but hey thx alot for your help
