Hey Guys,
This is the last piece of the puzzle... I am putting a Corsair H60 on a 2600k chip and plan on over clocking using Asus TPM. I am estimating it will hit about 4.6 Ghz.
My question is, being that Corsair does not sell the fans on the H60 separately, what is a reliable fan that I could use to act as the "pull" in the push/pull config? I will be using Corsairs included fan as the push.
The supplied fan puts out 75 CFM and Corsair has recommended I purchase one to pull that is also around 75 CFM. The issue is noise levels. Any recommendations on a fan that can pull off 75 CFM without getting too loud?
Also, can Sandybridge do ~4.6 Ghz with a H60 only in a push configuration without worrying?
Thank you!
Thank you!
