Hi everybody.
I am new in this forum and I need help on a big problem I am having. I hope you can help me.
I need to erase all bios and flash a new one since it´s highly possible there lies a virus in it.
I already contacted my antivirus support, Kaspersky, but I had no solution for it yet, although they confirmed me there is a virus in the pc (for those interested and that can contact Kaspersky for further information, I inform here the last protocol number in www.kaspersky.com.br of a series of relates I did, in portuguese: 313959109).
Some weird behaviors that the virus cause is offline actualization of the registry in the windows installation process, almost equal to the number of errors AVG detects in a system scan in UBUNTU Linux (files with permission denied and files absent), and also changing permissions in files, disk and directories, unknown users and groups in the system, changing windows system files, hidden network drives, and so on.
Problem is difficult to result, for instance see:
http://www.tomshardware.com/news/bios-virus-rootkit-security-backdoor,7400.html
and
http://forums.cnet.com/7723-6132_102-281792/can-viruses-be-removed-from-the-bios/.
In the actual stage of the evaluation of the problem, after I used bios flash utility (MB ASUS M4N68T-M LE), It happens that with 4096Mb of memory, the bios reads usable as 3860Mb, and it readed 2560Mb before with video card plugged on the MB.
Bios is updated to last version available in ASUS website.
Through afudos /i<biosname> /pbnc it stops erasing bios in 81% and I really need to erase it all (100%).
By now, it seems to me that through this way I will be free of the virus.
The help I need is the parameters for afudos (version 2.41, last in ASUS website) to fully erase and flash a new bios, and also, if possible, a parameters in afudos to copy the entire content of the bios so I can send it for the support of the antivirus I use.
If possible, a link of the manual of afudos would greatly help, since I didn´t find it in ASUS website in the page of afudos download for the MB i cited above.
Thanks for your help !
Andre.
and
Andre.
