Help needed sn41g(v2 i THINK)
Nasty_Savage
Extremely [H]
okay. the revision on the motherboard is version 2.0, that's a v2 right? My problem is, I flashed the Bios to the latest revision to get the 400 FSB, but the issue is it will not recognize my Barton +3200. It reports as an +1100 no matter what I try. Any suggestions? :(
Apparently v 3.1 on the motherboard is the v2. Luckily, I was able to flash the Bios to the right revision. I clocked up the memory to 200 (400 DDR) and it correctly recognized my Barton +3200. I am running Prim95 now to make sure its stable. Any cooling tips? :D :cool: :D
Thought I heard Steve mention something about blowing in instead of out. At this point it appears as if I can use this baby as a hair dryer. :D
Blowing in on this system is generally worse than out. I tried both on mine. MIght have had something to do with my 9800 Pro, but I doubt it. It was about 8C cooler blowing out on the case, and 4C cooler on the CPU.
