Help Needed...Is my Mobo or CPU dead?
tbonepat11
So i just put together a A64 2800+ and Chaintech nf3 250 754 board. I installed all the components and OS and everything is great. This morning the whole system just suddenly shuts off. I try to turn it back on but nothing. I fiddle with it and i turn it on and the cpu fan spins for like 2 secs then off. Now it is completely dead and I get no beeps at all. I have switched out the power supply and its not that. I have no means of testing the CPU or Mobo in another system. I want to RMA it but i do not know what is the culprit...the mobo or the cpu. I have tried resetting the CMOS but does not help. Any ideas would be very helpful. Thanks in advance.
It could be many things, but it sounds as though something is going to ground that shouldn't be. I would disassemble it, being very careful to look for a stray screw or something else out of place, and the reassemble it to a barebones state (that is, only the components necessary for it to POST). Only one stick of memory if you have multiple, no drives, nothing but the video card, memory and CPU. You are just trying to get to the POST screen at this point.
If you can't get it to POST, I'd suspect the motherboard more than the CPU, unless you have some reason to think you may have fried the CPU, such as a poorly mounted heatsink, etc.
I had the same problem before with the same board. Give this a try:
1) Unplug all of your power connections (HD, Optical Drives, Floppy) and try to boot with only the CPU, ram and video card.
2) If you can boot with just the CPU, ram and video card then one of your drives could be at fault. Start by pluging in one drive at a time and then retest. Contiune to do so until you are unable to fully power up your system.
Lastly, you are certain that your power supply works?
Thanks for replies. Yes I am sure the power supply works. I tested it in my other rig and it ran fine. I also tested the PS from the other comp in this one and it also did not work. I will try your advice and report back.
Just tested it with the Mobo, CPU, Mem and Video Card plugged in and there is no response at all. At this point I think it must be the mobo. Any other suggestions will be appreciated. Thanks,
not at all....there is a faint buzz/whining from the PSU when i plug it in...that is it. There is no activity at all no matter how much I mess with it.
