Help needed in data recovery process, big thanks for help!
TheDarkTao
First off, thank you all soooo much for getting me to where I am :D
Quick update.... I tryed to transfer drives to a new mobo, and re-set them in raid one.
For whatever reason gigabyte rebuilt it so that all the data was dumped onto one drive, so yes it looks as though it is recoverable :D
But I am scared as hell to lost what I have found :(
So, all the data is in tact, and I used filescavanger to find it all. Only problem, is I cannot access the drive, since vista wont let me use it till I format (dont worry I wont ;))
But what can I do to get all the files out of there? Even if I copy the image to another drive, can I then use the data? Would seagate program allow me to copy it all as an image, and if the other drive was formated could I access it?
BTW does anyone happen to know of a free version of filescavenger, I cannot afford 149 to use the program :eek:
Thanks so much for the help in getting me to this point :D And further help is just that much more awesome.
I love you [H]ardforum!!! And that is not just the beer talking :p
TTT....
I am kinda dying without my data back.... :(
I just don't want to mess up on data recovery, anyone know any tips, or programs that could help.... You would be super spiffy ultra cool if you did :p
