Wasn't sure which forum was the best location for this, but I figured that hardware hackers and modders would be most likely to know.
I have a late 2005 Powermac G5 which refuses to power up. I have got the thing mostly dismantled, but am failing at final hurdle. I am trying to get the PSU out as I gather it is like to be a failed capacitor or similar, but I cant get the PSU out without removing the mobo. I cant get the mobo out because the front panel audio/USB/power board is in the way:
The PSU wont come out on its own as there are a bunch of little feet below the edge of the mobo (for which I have removed the screws) and whilst the PSU will slide a short way towards the front of the case, something is impeding it and I think I need to get the mobo out to make this easy. Which it would do if I could just remove the freakin' front panel board
The mobo itself is unscrewed and also slides a small way toward the front of the case.
Anyone done this before and know the answer? Thx
