System is a Zotac IONITX-F-E (mITX). There is no optical drive or floppy drive attached. 4GB of Kingston DDR2 Thermaltake 200w PSU (stock with the thermaltake element Q case) There is no external GPU or any other hardware (other then monitor lb & mouse) connected.
Essentially I can pull the power & hold the power button in for a few seconds & then plug the power back in & it will boot to windows fine. However it will not reboot after being shutdown (same if I choose reboot). This also occours if I am at a DOS prompt & hit ctrl alt del
when it fails to boot the fans come on, but no video & no numlock so its stopping long before the OS takes over.
The bios is quite out of data, but I have not been able to update it (and I have been trying for the past several hours) as I get "46 - Error: problem getting flash information" when trying from windows or from DOS following Zotac's directions.
Anyone have any other ideals of what may be causing this behavior as I would really like to be done with messing with it as its a gift from santa claus to my daughter tonight.
