Help need tuniq tower thumb screws.
jawasmell
Can anyone help,i am working on modifying my tuniq tower to fit on my am3 board but i need two more thumb screws.
The two amd thumb screws that come with it.
If some one as used it too mount there intel our just don't use there tuniq anymore,they probaly won't need them.
Of coarse i am happy to pay for them might need to be someone in the uk since thats where i live cheers.:)
No i bought a metal back plate for a thermalright ultra 120. The board is a msi 790fx gd70, But i need four screws all together to mount it.
You're going to need to know the size of the threading in the backplate's holes to purchase the right screws.... did it not come with any?
The treading size is the same as the screws that screw down the motherboard or the psu to the case whatever that is?
Can anyone tell me what the thread size might be? It is the same thread size as the ones you use to attach the psu to the case. Maybe I can find an equivalent on line Thank you.
