the_village_treky
- Feb 3, 2004
im using a celery 400 mhz for a sience fare, and i was planning on useing the bios to check tems(project is a bong cooler). enywhay, i start up the comp, go into the bios(windows is screwed btw, so no chance of that working) and i cant find a temp read out. its an old bios(not modern alyout, it has for windows you tab between and then lists pop up). enywhay, what i need to do is find a whay to get the temps on this with its stock hsf and with the wc set up.. whats a nerd to do?
