sPaNkThEmOnKeY
- Feb 28, 2003
I just purchased a Y.S. Tech 120mm (FD1212257B-2I, 12volt, 5.52w) fan that I am going to stick into my case. It has the normal 2-wires leading to the molex connector.
When I plugged it into the PSU, it uses all 12 volts and spins fast, which suprisingly to me is very loud.
At my local retailer, we also plugged it into the Antec 380w PSU (the one that comes with the Sonata) using the 7 watt fan connections and the sound is perfect. Unfortunately, I don't own this PSU.
I would like to add a resistor to one of the fan leads to reduce the voltage down to approx. 7 watts. Can anyone tell me what resistor to purchase? Hopefully I can purchase it at my local Radio Shack. (If you can provide a link to resistor, that would be cool). Would I install the resistor on the red wire?
sPaNk
sPaNk
