Aug 4, 2004 #1 M Machaera n00b Joined Jul 28, 2004 Messages 2 I installed the Cat 4.9's, but they caused doom 3 to stop working, as well as causing 2d performance to drop to where I can see redraws happening. I uninstalled them and reinstalled the 4.7, but the behavior continues. Help!
Aug 4, 2004 #2 P PadanFain Weaksauce Joined Aug 2, 2004 Messages 122 very odd 100% positive you removed ALL traces of the driver? If so then a format might be worth a go...
Aug 4, 2004 #3 S Shane [H]ard|Gawd Joined Feb 20, 2003 Messages 1,356 uninstall them again in safe mode... then delete the ati directory reboot then install the new 4.9 drivers and should fix the problem.
