Tman said:(sorry if this should be in the watercooling section. I was not sure)
Here is my pump
Link to Frozen CPU where I bought the pump.
Here is my problem-
My pump will not turn on.
It kicks over (cant do it every try) if i wiggle the wire / pull it out and push it in. So that
leads me to believe that it is a loose wire inside my pump.
And yes I have tried a different wire and Power Supply.
What can I do?
