I am trying to help my buddy build a watercooling setup. I will be doing my first build and have done research, but I am using only the best parts. He cant spend as much and is trying to compremise on parts, yet I am not familiar with the ones that he has sent to me. If someone more knowledgable then I could take a look I would appreciate it. BTW, price is very rigid and can pretty much only be cheaper (well a few bucks wont matter). Here is what he sent me.
Just in Case: The case I will be using is a Thermaltake Soprano
This is the configuration I am looking at.
Radiator:
Stealth GTS 120 Black Ice
$42.95
Water Block
Copper TDX Block for Intel 775 Processors
$52.95
Pump
Danger Den MAG II LE
$39.95 (I would like a 12V one so I would not have to plug it in an outlet)
Reservoir
Danger Den Dual 5 1/4" Bay Reservoir
$31.95 (Do I even need one of these?)
Fans
Thermaltake High Performance 120mm Case Fan
$Already Owned (Will I have to cut a whole in the top of the Case or get an additional fan)
Tubing
ClearFlex 60 Tubing 1/2" ID 3/4" OD x10 (10 feet)
$11.20 (Do I really need 10 feet? What does ID and OD stand for, will this work?)
Clamps
Plastic Snap Tubing Clamps x 10
$7.50 (Is 10 good?)
Coolant
Zerex Super Coolant 12oz
$8.50
Sub Total = $195.00
Shipping = +$12.55
Total = $207.55
Not Bad Since the Parts Seem to be decient. =)
Thanks!
Radiator:
$42.95
Water Block
$52.95
Pump
Reservoir
Fans
Tubing
Clamps
$7.50 (Is 10 good?)
Coolant
$8.50
Sub Total = $195.00
Shipping = +$12.55
Total = $207.55
Thanks!
