Phrozt
- Apr 20, 2007
Ok... so you may or may not have seen my FINAL BUILD thread.
Well.. my computer did. I need this thing to last for like.. 4 more days till my parts get here and it craps out on me because it's all emo that it's going to get replaced
. I can't tell what the prob is!! I think it actually might be the motherboard, because there's several things that I've tried, and they've all worked for a bit before dying.
What happens is the comp will start booting up and then blank screen. The LCD will flash because it's trying to get a signal. Sometimes it will get as far as the XP loading screen, but will die before the blue login screen. Other times it won't even show the POST screen. I've tried swapping HDs, reseating things, and swapping vid cards. When I swapped a vid card, it actually booted to windows.. I logged in... and it worked until I tried to change the refresh rate of the card.
After that, neither card will work. Also... after messing w/it enough, the mobo reset to factory defaults. I've looked all over the board but I can't figure out where a short might be.
Here's some info:
- Thermaltake Tsunami Dream case
- p4 3.2Ghz prescott
- Aspire 520watt PSU
- ASUS P4C800-E Deluxe
- ZALMAN CNPS7000A-Cu 92mm (Arctic silver 5)
- 1 60 GB IBM Deskstar 60GXP
- 1 120GB Western Digi
- 1 320GB seagate 7200.10 sata
- Viewsonic VX922
I grabbed some stats from the bios:
3.3v fluctautes from 3.232 - 3.248
5v flucs from 5.053-5.026
12v flucs from 11.673-11.612
These would change about every 2 seconds or so.
Also, the "Power Temp" was posting N/A but jumped to a weird red negative temperature for a half a second a few times.
The above stats were taken after the computer was allowed to cool down for about 2.5 hours. I remembered my mobo temp being around 34-35C before, and now it's at 25C.
I'm thinking either the Mobo or the PSU, but I don't know for sure...
Anyone have some insight?
Here's some info:
- Viewsonic VX922
