Help my e8400 E0 find a new mobo!
NGX
Hey I recently picked up a e8400 E0 and 4x1gb of Ballistix Tracer 1066 D9 modules. I have no idea whats goin on in the world of chipsets and would like advice on which mobo to buy. I want to go crossfire, prob two 4850's so no p35/p45 boards unless they clock VERY well, as I will be clocking a lot with this board. Thanks
Asus P5Q-Pro CrossFireX / P45 hands down
cannot be beat for the price
x48 is a waste of money
Price/performance, I'd go with a good P45 board. I just grabbed the P5Q Pro last week and I can't complain. I can't imagine the Crossfire performance is hampered $100 worth.
If you are considering the P45, I'd get a Gigabyte EP45-UD3P. I'm currently running mine at 7.5 x 534 fsb
Either the Asus P5Q or the Gigabyte P45 board. I've no experience with the Asus board but it's got glowing reviews and the 8-phase power looks awful sexy.
I see no reason for an X48 board - the difference in oc (if any) just doesn't justify the expense. And the X8 lanes in crossfire mode make absolutely no appreciable performance difference.
I just picked up a Gigabyte P45 board (UD3P) due to it's awesome reviews. I won't be crossfireing anything (I'm not an ATI guy) but I loved my P35-DS3L for it's stellar overclocking and rock solid stability and I expect the same performance out of the P45 board.
Best deal is a P5E open box from Newegg, then crossflash the BIOS with the Rampage Formula BIOS. I did that and ended up with heck of a board for $135. :) Probably only a good route for an experienced user, if you already have an audio card to use, however.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131219R
Open box comes with just the motherboard.
Rampage conversion thread: http://www.xtremesystems.org/forums/showthread.php?t=179580
Right now, my P5E (Rampage BIOS) is humming along @ 533 FSB stable with very little vdroop. For $135, it is hands down the best board available, if you are into it. I'm about to up the FSB to 550 and see if it's stable.
Update: P5E (Rampage BIOS) seems stable so far @ 550 FSB.
Also consider a X38 board, you can find some good deals on them. Also keep in mind that most boards had to have a bios update in order to support the E0 stepping. There is a chance that a new board won't have the updated bios and won't see you processor when you try to boot. If you have a spare 775 cpu, boot with that then update your bios. Then swap in your E8400.
By the way, you will love the E0 stepping. I just put a E8500 E0 in Gigabyte X38 and I'm running @ 4.03ghz on only 1.29 volts tested stable with 4x1 Crucial Tracers 800 running @ 1010mhz :D
Wow thanks Exeodus and Starcrossed, those are the numbers I like to see :D. If you are seriously stable at 550 fsb, then thats the board for me. It looks likes im going to be buying the P5E and doin the bios update, that looks to be the most promising for clocking and price. Thanks guys
Go with a P45 board because 4850's don't need the extra bandwidth of the X48. Also you are putting such importance of high FSB it should be noted that the P45 has the FSB record at like 700 something. I have run my P5Q Pro at well over 500 plenty of times.
Make sure you flash it before installing Windows, so you get a good, clean install. Also, if the BIOS name is abbreviated in DOS when you are using the flashing utility, you'll have to use the abbreviated filename to flash it. Once you do the initial flash to a Rampage BIOS, you can flash using other flashing utilities, as long as you continue to use a Rampage BIOS.
Yeah, I've had no errors, thusfar, at 550, and I'm thinking it'll go higher. We'll see, though, I haven't tested it for a long time, yet. To add, I get very little vdroop. (That 550 is also with four sticks of RAM, rather than just two.)
I'm using Rampage Formula BIOS 410. You'll get a bare board with the open box, so don't expect the sound card with it. It may come, it may not. My open box had absolutely nothing but the board itself. So you'll need to have a sound card. I didn't care about it, because I already have a nice soundcard. Also, make sure to reset your BIOS settings, after you crossflash. It is a switch below and to the right of the uppermost 16x PCI-E slot. Like I said, it's for the experienced, but for $135 it's worth it.
Let us know how it goes. I hope it goes well. If you get a dud of a board, return it, and get your money back. They may charge you 15%, I'm not certain, but for the $20 + return shipping that you'd waste, I'd say it is worth a shot. I'm not the only one that has gotten very good results with the P5E/P5E Deluxe/Maximus Formula/Rampage Formula, which in essence are the same motherboards.
I'm supposing, by virtue of the fact that you know about D9 and got your hands on some for overclocking purposes, that you also know what you getting into. :)
Haha much thanks to you Starcrossed, you seem to know what going on, and I like that. I just ordered a open box P5E-Deluxe from the egg, I hope it will flash...? Ive got a pretty good idea of what im getting myself into ;) and I hope to fill everyone in along the way. I may possibly do a v-droop mod and a few other things depending on how the voltages and board react.
Anyway within the next few days I will have very similar setup to what you have, 4x1gb sticks of ram, e8400 in this board so if I have any questions I know who to pm :D
The P5E Deluxe will work fine with the crossflash. Good luck, bud. Like I said, let us know what's up when you get it running. ATM, I'm 550 stable (on air, no mods) with an E8400 (7.5x550, 4.125GHz) and 4x1gb 1066 (1.1GHz.) One the nice things in the Rampage BIOS is the tRD (Performance Level) setting for the RAM. Anandtech has an article about it: http://www.anandtech.com/mb/showdoc.aspx?i=3208 You can also set the tRD via MemSet 3.5 (there may be a later version, it was written by a guy that frequents the Xtreme Sys Forum); however, that can only be done in Windows, so the Rampage BIOS is an advantage.
Thanks. Ah that brings back memories of memset and setfsb lol. God Im so looking forward to this you guys have no idea.
P5Q-E is a really nice board. Got one o dem and I also have a P5E which I love. Both excellent boards.
Yeah, I went without a PC for a while, and it was nice to build one, again, a few months ago.
The poster explicitly said he didn't want a P45, and the P5E is a superior board, IMHO, with greater options; yet, how many of you posted P5Q?
Here's an Xfire comparision between an X48 and P45: http://www.tweaktown.com/articles/1472/10/intel_p45_vs_x48_crossfire_performance/index.html
x8/x8 Crossfire isn't at all efficient as resolution increases. This thread totally irks me.... :rolleyes: Goes to show what popular opinion is worth! hehe
Please educate yourselves before educating others.
Well, I've owned both the Maximus and the P5Q Pro. FWIW, if you're not using crossfire (which I'm not), you really can't tell the difference between the two.
As noted above, the real question is whether or not an X48 is worth the $100 more than a P45 board with i7 around the corner.
That is an entirely different discussion. :rolleyes:
BTW, I hope your flash goes well.. It is a chance that you are taking. That being said, you may find yourself fine with the P5E Deluxe BIOS. It has been reported as a better BIOS than the P5E. My flash went fine, obviously, but I was entirely prepared to RMA the board to Asus and buy another had it failed.
Lol, word. Anyway I am prepared as you were, I have rma'd many boards to Asus so I know the drill. The board should be here on the 10th, damn ground shipping. Anyway, I wanted the x48 chipset if possible only because it has a 1600mhz system bus, which I plan to use to the full extent :). That and Im pretty sure that the x58 is only going to be a stepping stone before the next big advancement in intel chipsets so x48 will b the way to go for a while. Cant wait for to build some custom cooling for this thing as well, thinking of just chilled water for now, around 4C until something like a phase.
Reason I recommended the P45 is because you placed great priority on overclocking, which the P45 is much better at then the X48. Not that the X48 is BAD at it, but the P45 overclocks better, hands down and specifically on quads.
Also check out some X38 boards. I don't know if it's still the case, but when my 965 board died and had to pick a new one all the X48 board were a lot more expensive then their X38 counters.
Ok so I got most of my parts, still waiting on two 3870X2's, a non-anus (stock) heatsink, and a decent optical drive, but im going to go ahead with the flash and play around a little bit. Ill post pics in a minute or two
Ok I flashed to 0410 as well. Im installing vista 64 bit as I write this. I havnt done any clocking because the stock hsf is a piece of crap and I don't want to take a chance. Everything looks to b fine, I disabled the second LAN and the three opt sensors. Will post after drivers and benchmarks are installed
