help, my computer wont turn on
All I did was unplug the power cord to the psu, plug it in another computer, then put it back. After that it wouldnt turn on. I took the leads from the power switch, thinking it had gone bad, and hot wired them together. I turned on the switch on the psu, and it looked like it was going to start, the fans started to run for a second, then it went dead. Im getting power to the mobo, as evidenced by the power on led on mobo. What the F is wrong with my computer??
thanks.
I hadn't been in the case at all though, so I don't see how I could have messed anything up. All I did was switch the cord, and switch it back??
To eliminate the power switch as the problem, I took the two leads and crimped them together. Should they stay like that, or are they just supposed to make contact to start it?
thanks
Arcygenical said:
THey're momentary. Having them perminantly attached will power down the board.
What he said ^^
once they touch they turn on the PC but if kept together it just powers it off again. Uncrimp those wires and just touch them together, that should keep it on. If that's not it then I'm confused with you :)
So, that worked fine and last night I powered up my pc. This morning I went to turn on my monitor and it had crashed over night so I was looking at blue screen. I tried to start it again w/ the same method, touching the wires together, but this time nothing. mobo is still getting power, but it won't start.
thanks
hmm, If you can get into the bios try running it at normal clock speeds. If you're talking about the rig in your sig then I'm not sure... It seems that system is nicely balanced and shouldn't really have any stability issues but IDK
yup, that's the rig. I ended up taking it to this guy to look at it, and after unplugging everything from the mobo and plugging it back in, it works. Unfortunately now I have to either replace the whole cable that has the led's and reset and power switch on it, or find the tiny switch that broke and solder it on, and I'm no solder expert.
Now that the switch is gone, do I have to get a whole new cable, with the LED lights, and reset and power switches, or can I just get that tiny plunger, switch, thing, and solder it on?
Is the original switch ruined? If not just resolder it to that. Or you can get a cheap momentary button from radio shack and use that
The original switch is broken. Are those universal, or per case manufacturer? I'd like to get one that will snap back into the case so I can use the case power button.
Still underlying re-start problem though. Yesterday I had to power down because my chipset fan was acting up and when I went to restart it, it was dead again. The same method allowed me to re-start it: I unplugged the main to the psu, and unplugged the motherboard and auxiliary power plugs, left it while I went to the store, plugged everything back in, and it started right up. What could be causing this?
thanks
<bump>, <bump>
Really looking to try and diagnosis this problem, if anyone has some ideas. Someone on another forum mentioned static build up, but I'm not sure how to handle that.
thanks for any help.
