Help, my computer is on crack!
Zatos
I dont really know what forum this should go in, but:
I'm not really sure what happened, but my computer is way whacked. I was trying to install some older NVIDIA drivers (graphics card) and well... things haven't gone so well. Sure maybe I should have removed the old drivers instead of just installing over them but it doesn't help me now. It asked to reboot, via the NVidia software, so I said okay.
At the same time during this, when I rebooted, I went into the bios and set the display init first or whatever it is from PCI to PCI express. I dont know if this really had anything to do with it, but I'm just telling you what I did. When it gets into windows, I realize my mouse isnt working and that the sounds are all high pitched, like they are being played really fast. The desktop doesn't come up, instead it acts like it is installing the NVidia drivers again. So I let it go and then it wants to reboot again and so I say okay and then nothing. I brought up the task manager and had it choose to shut down, and instead it kills the install program and brings up the desktop, but I reboot anyway. So after this, my mouse is no longer working, and the noises are all high pitch. I see that in fact, i dont think any of my usb devices are working. I got an error message stating that an unknown USB device is malfunctioning or something from Windows. Also, I uninstalled that driver, but somehow there is still a hardware install running in the background I have to kill. I have tried uninstalling the driver, repairing Windows (using the install CD and reinstalling over it, via the repair option) but it came up with a BSOD (unformattable boot volume I believe and it was running really slow)... I tried cleaning up my registry... no dice. I also tried resetting my BIOS values to defaults, but no changes. At this point I am ready to reinstall Windows, but after having seen that BSOD it makes me rather concerned I'll just end up with nothing at all. I really dont know what to do, I have never seen anything like this before. Not only does just the audio play high pitch, it seems like maybe the computer itself is trying to run at twice the speed. I played a video, and it also, runs twice as fast.
Here is my hardware:
DFI Lanparty NF4 Ultra-D
AMD 3700+ San Diego
MSI 6800 GT
I guess thats probably all that matters in this scenario.
Thanks for ANY help.
I just did a system restore to yesterday morning before I made any changes. STILL the same thing. I fear there is something far more sinister at work here...
Hi Zatos,
FYI - Whenever you replace hardware you must always uninstall all previous drivers and software prior to new installation and then reboot. Windows will try and detect but just cancel
so that there is driver.
1. When you reset the BIOS did you re-enter your basic system requirements. IE If you have a soundcard did you disable the on-board audio
2. What changes did you make to the registry?
3. Have you tried to uninstall all incorrect drivers yet?
4. What happens when you boot into Safe Mode?
5. Is the older GFX driver compatable with any newer DirectX install and all other software?
To sum up, 'cos you have changed so many things from the BIOS, registry and drivers it may be extremely difficult to find the problem and a fresh XP format and install may be the way to go.
Do you do regular full back-ups of your system? Maybe you can restore computer to a previous state and then do the GFX install properly.
1. Yes, everything is set proplery in the BIOS. I use onboard sound.
2. Removed only incorrect entries. I thought maybe there was an entry perhaps causing the strangeness.
3. I have uninstalled the drivers and reverted back to a prior system date.
4. Safe mode... same thing. No audio obviously, but my USB devices arent working and things are still funky.
5. It should be, both of them were released during directx 9.0c.
I think you were responding before you saw my second post. I would have really thought that if it was something inside of Windows it would have been fixed by using system restore. Now I am extremely confused.
What about disabling USB in the BIOS and disconnecting all USB peripherals and rebooting
Well... it must have been a power malfunction somewhere on the motherboard... because I powered off completely... and now, we are back to normal!
