Help! My computer fell over and won't POST
Disconnect
My computer refuses to POST - no beeps whatsoever, but the fans and drives spin. I have checked or replaced all basic components, but nothing works. Needless to say, I won't be using my computer as a foot rest again!
Specs:
-Mobo- Gigabyte GA-965P-DS3 rev 1.0
-E6600 @3.33GHz w/ Tuniq Tower 120
-2x1GB SuperTalent DDR2 800
-8800 GTS 320
-Corsair 620HX
-Centurion 5 case
-1 hard drive, 1 optical, fans, PCI cards
I'll go through what happened:
When the computer hit the floor, it immediately shut off. I opened the case and confirmed everything was in place. Then I turned it on. The hard drive and fans spun up (including the video card fan), but it did not POST. I smelled something burning and switched it off.
Then I took all components out of the motherboard and re-mounted only the CPU, one stick of RAM, and the video card. No Luck.
I tried again, and this time it worked! But never again :( I did go into the bios and confirmed that temperatures and voltages were normal. Next, I tried it with the hard drive, and it again failed to POST.
I tried a few more times with only the basic components and the motherboard out of the case, but nothing worked. I tried removing the LED/button connections and starting with a screwdriver. I started the system without memory to see if it gave a post code. I also cleared CMOS many times. Nothing changed.
At this point, I assumed that the PSU was fine since the fans/drives worked and that the CPU was not damaged since the system POSTed once. This left the motherboard as the only logical culprit.
I then ordered my exact motherboard off of ebay from someone with a good history. I mounted the new motherboard in the case and connected everything. It also failed to POST, exactly the same as before. I again tried clearing the CMOS and connecting only the basics outside of the case with no luck.
I had checked the CPU, memory, and video card on my work PC while waiting for the motherboard. They were fine.
It looked like only remaining possibility was the PSU, so I ordered a new one (620HX again). This did not work.
With a PSU, motherboard, CPU, memory, and a video card, the system should POST. All of these have been replaced or tested, but they do not work together.
The only possibility I can think of now is that the replacement motherboard from ebay was bad. Or perhaps the first PSU killed both motherboards without touching the other components.
Maybe I'm missing something... Otherwise, I'll buy a brand new board from Newegg and cross my fingers. I don't want to reformat, but at this point it doesn't matter.
Any advice would be appreciated.
Help!
id say if you can test the hdd(s) in a different system with hd tune (pro) and see if they are the problem.. generally thats the first thing i do if a system is dropped or falls over since they are the only thing in a system with actively moving parts..
if the hard drive ends up not being an issue id try troubleshooting it in this order:
and 1 by one swap parts out.. so first boot all the original parts.. second boot replace the cpu.. if it fails put the old cpu back and replace the memory.. see if it boots.. if it fails.. put the old memory back and swap the gfx cards.. see if changing one of those allows the system to post.. if not go crazy and just swap things around see if you can get it to post again..
I did connect the hard drive at work since I needed some files for taxes... but the HD isn't needed to post.
I know the cpu, memory, and vid card are ok. The only things I haven't tested with another system are the mobo and psu, but I replaced them both.
