Help! Mounting the Motherboard!
khlueh
I'm trying to install a micro-atx board into a larger case. The case says it supports micro-atx, however, when I line up the board with the case I notice that the case does not accomodate a hole for one screw on the motherboard. Is is absolutely neccessary that the motherboard be grounded on every standoff?
Depending on where that missing screw is located the board may become unstable, and when pushing an extension board into it's slot or RAM modules... it can bend and even break apart. Just be carefulll when pushing someting onto it that you hold that corner where the screw is missing.
