help..memory incomatible problems!
jonneymendoza
hi, i have a GA-8IPE1000 gygabyte mobo for pentium 4 and my ddr 333 corsair 2x 512mb does not function properly with this mobo.i use a memory test called Memtest86 and i alwaz recieve loads of errors. i have tried 2 overclock my memory into 200mhz ddr400 raisng the memory vollgate and still did not function properly, i have read the specifications for this mobo, and it stated that it can support ddr333 :( my memory works fine on my old MSI MS-6526 micro atx mainboard with a fsb of 533...
what can i do 2 solve thr problem? i have a brand new p4 3.2 northwood and cant even use it!!!!!
Well I would put one chip in and run memtest and the swap them out and test again just to make sure they are both error free. If both of them get errors, then it might be the memory slot. Try another one with each stick (if it will let you) and test.
I know you said they were good in an old machine which leads me to believe it is the mobo, but you never can tell. You are just going to have to test all the combinations with the mem sticks and the mem slots.
