help me with VC install error Machine_Check_exception
taurus252
I recently purchased a xfx gtx260 after installing it I boot up and get a machine_check_exception blue screen_9c. Now I had this same exact error message a while back when trying to install another vc but chalked it up to it being a bad vc, but now IM assuming I must be doing something wrong. Any help is greatly appreciated, below are my stats.
I also brought new memory but my machine still shows me as just having 2gbs and not 4...any reason for that- please help anyway
Asus P5N32-SLI SE Deluxe, NVIDIA nForce4 SLI X16 Intel Core2 Extreme/Core2 Duo
Intel Core 2 Duo E6600 1066MHz FSB 4M shared L2 Cache LGA 775
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 800 (PC2 6400) 4-4-4-12 Dual Channel Kit
2 x Geforce 7950GX2 1GB 512-bit GDDR3 PCI Express x16 Dual GPU Video Card
Western Digital Raptor 150GB 10000RPM 16MB Cache SATA
xp sp2
http://www.aumha.org/a/stop.php#0x9c
This is a hardware issue: an unrecoverable hardware error has occurred. The parameters have different meanings depending on what type of CPU you have but, while diagnostic, rarely lead to a clear solution. Most commonly it results from overheating, from failed hardware (RAM, CPU, hardware bus, power supply, etc.), or from pushing hardware beyond its capabilities (e.g., overclocking a CPU).
Not real helpful... Maybe there's an issue with your northbridge if you're having memory weirdness and errors with multiple video cards? *shrug*
Oh, you didn't list your power supply. What PSU are you using? Got another you could try?
i see this is a very vague issue- gonna have to fiddle with a few things i guess...my powersupply is Antec TruePower 2.0 550W Power Supply- thanks
