Originally posted by plot
whoa, get a schematic editor... lol. if you have Visual Studio, it contains one (sorta), using one of the programs in there nobody ever uses... heh, can't think of the name. i use orcad pspice student edition, but i think it costs money... (i got it from school).
anyways, i'll take a look at the circuit later, i gotta run now though
one question though, Ix, is that a dependent current source? Where's the 2 Amp source?
Originally posted by groggory
sorry, my editor is on my computer at home. I'm at work right now just working on my homework. So sorry about the crude drawing....
Ix is just showing the direction of current, as stated in drawing in the book. It is not any part of the circuit, only there for reference purposes.
The 2A source is that circle with an arrow in it. That is standard notation for an independent current source.
A dependent source looks like a diamond with an arrow in it with the dependent variable next to it. Something to the effect of ' 2Vx ' or something like that.
wheres the ground?
i got -360watts on a pspice simulation
A B
.--[100 ohms]--.
[+] (^) 2A
[-] 100V (|)
V
Originally posted by gee
pretty straightforward... simplify the circuit to a series connection of a 100V voltage source, a 100 ohm resistor, and a 2A current source, like so:
Code:A B .--[100 ohms]--. [+] (^) 2A [-] 100V (|) `-------.------' V
Point "A" is 100V, obviously. The current through the resistor is set by the current source as 2A, which results in a voltage drop of 200V across the resistor - thus point "B" is 300 volts.
The current source is therefore providing 2 amps at 300 volts, which means it provides 600 watts, or "dissipates" -600 watts.
Making sure power is conserved... 2A @ 100V means the voltage source dissipates 200 watts, and I^2*R on the resistor gives a 400 watt dissipation. 600 - 400 - 200 = 0. yay!
