86 5.0L
- Nov 13, 2006
I finally managed to score a 480mm radiator for my watercooling project. Now I need help exhausting the heat outside the room. I have 3 options more or less
Option 1, is a window towards the west, so for about 5-6 hours the sun hits this window, I can maybe fashion up some cover so the sun doesnt hit it directly.
Option 2, my closet used to be where the washer and drier lived, since then, they have been moved outside and now I have a heat extractor mounted in the ceiling, now im not sure if its been shut closed from elsewhere.
Option 3, probably the least easy, is running coolant lines outside thru the wall where the A/C unit is mounted and place the radiator outside. this would also mean the radiator gets sunshine most of the day.
so [H] which would you choose? or any other ideas?
