help me with the final pump decision
I have the Alphacool 1510 pump. Would I recommend it, no, unless you do not care about noise. I have mine mounted in such a way that vibration should not be an issue. When it is on its lowest setting it is not. If you need the 20 ft. of head pressure there is going to be noise on the 24 volt setting.
I have never had a laing pump but I have never seen anyone complain about them.
I chose the 1510 because of the setup I was useing. I had a D-tek fusion, 2 EK 8800 GTS blocks, An EK 680i block and 3 radiators. I thought it would help temps to run it at its highest setting but in reality it did not.
i checked the alphacool 1510 myself, but the separate voltage regulator and the nonexistant availability put me off a bit
though, an awesome pump for a reasonable price
d5 vario has always been in my shortlist, forgot to add it to the first post :p
so it's either that or ddc+custom top
