help me with my build please :-(
Friendlypirate80
what do you guys think ? its for gaming and porn lol
Thermaltake Tsunami VA3000BWA Black Computer Case 108.99
http://www.newegg.com/Product/Product.asp?Item=N82E16811133132
Antec TRUEPOWERII TPII-550 550W Power Supply 89.99
http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
AMD Athlon 64 3700+ 1GHz HT Socket 939 Processor 212.00
http://www.newegg.com/Product/Product.asp?Item=N82E16819103539
EPoX EP-9NPA+Ultra ATX AMD Motherboard 105.00
http://www.newegg.com/Product/Product.asp?Item=N82E16813123236
G.SKILL 2GB (2 x 1GB) 184-Pin DDR SDRAM 138.99
http://www.newegg.com/Product/Product.asp?Item=N82E16820231047
Western Digital Caviar SE16 250GB 3.5" SATA 3.0Gb/s Hard Drive 96.00
http://www.newegg.com/Product/Product.asp?Item=N82E16822144701
NEC Black IDE/ATAPI 16X DVD±R DVD Burner Model ND-3550A 38.99
http://www.newegg.com/product/product.asp?item=N82E16827152058
SONY Black 1.44MB 3.5" Internal Floppy Drive 9.99
http://www.newegg.com/Product/Product.asp?Item=N82E16821103116
eVGA Geforce 7900GTX 512-P2-N570-AX Video Card 539.00
http://www.newegg.com/Product/Product.asp?Item=N82E16814130279
Microsoft Windows XP Home With SP2 93.95
http://www.newegg.com/Product/Product.asp?Item=N82E16837102059
Logitech X-530 5.1 Speaker 58.99
http://www.newegg.com/Product/Product.asp?Item=N82E16836121118
Microsoft Comfort Curve 2000 Black Keyboard W/Mouse 24.99
http://www.newegg.com/Product/Product.asp?Item=N82E16823109156
ViewSonic VA902b Black 19" 8ms LCD Monitor 259.99
http://www.newegg.com/Product/Product.asp?Item=N82E16824116363
Total 1872.87
is everything compatiable ive been doing research on parts for days now
also do you guys think the gtx is overkill should i get a 7900 gt ?
thank alot guys also i do not plan on overclocking !
Nice rig ... you will get plenty of porn on that WDC :D
And gaming won't be too bad ether with that 7900 512 ;)
Two things:
1. I would strongly suggest AGAINST the Thermaltake Tsunami. I owned one for a short time and the plastic door cracked due to poor fitment of the 5.25 drive bays, the plastic door for the top aux. ports broke completely off, and the case was EXTREMELY loud.
For $10 more you could pick up a Coolermaster Stacker, or for $10 less you could pick up a Lian Li PC7 with dual 120mm fans.
2. If a 19" LCD is all you intend on buying, then a 7900GTX 512 is overkill. A 7900 GT would be more than up to the task of running any current and upcoming games at 1280x1024 with 4xAA enabled. Not to mention with the die shrink it has a ton of overclocking headroom and can perform on par with the GTX despite having half the onboard memory.
Everything else looks fine, well except maybe the keyboard/mouse combo. You're willing to spend $530 on a video card for gaming but not more than $30 for decently accurate input devices? I say downgrade the GTX and put the savings toward better speakers, keyboard, and mouse.
this comp is for my friend i told him to get a 7900 gt instead and safe money but he wont listen !!!
the graphics card is easy to upgrade in the future and th emoney i save i can put toward better stuff
