Help me with encrypting software for USB flash disk...
jyi786
I just bought a 1GB Sandisk Cruzer Mini. While I like the drive (small, thin, light, and large capacity), I don't like the encrypting software.
The software is called Cruzerlock 2. It's not a bad software, it just has 1 major flaw. You cannot encrypt a folder (directory). Cruzerlock 2 will pull every single file you encode from a directory and make it a single file.
Is there any other free 3rd party encryption software that will do this for me? I've used Kingston's Travelersafe software on their 256MB USB key, and it was perfect. It made a secure "partition" on the key, only accessible by username and password. A software that would do this equivalently would be optimal.
Thanks.
