iam preparing using todd lamle book for ccna and hotcerts.
com ccna guide , will i be able to go through the pass exams .
i heared its reall beast . wanted to know ur guys opinions
Lammles book is pretty good, but I wouldnt just read one book read several. For example, in Todds 5th ed Study guide, he has very little info on NAT. You may get questions or even a simlet about NAT on your test.
Another good book is the CCNA ICND Exam Certification Guide by Wendell Odom. Its a bit dry but he does explains subnetting thoroughly. You then can use the short-cut tricks Lammle teaches you about subnetting to really be prepared.
By the way, if you dont know subbnetting very well, you will fail.
Finally, you need a router for some hands on training. In the past you could probably pass without it, but now those simlets will kick your ass without real hands-on experience. If you cant afford a real router (check ebay) your next best choice is a router simulator from Boson or Network Visualizer v5 from Lammle.
Use any list of exam type questions you get (hotcerts?) to simply test what you know; do not use them as a brain dump or as a study guide.
Just to repeat, if you cant do subnetting pretty much in your head, you will fail.
Good Luck!
