Help me with budget(500)
panthal01
Anyone have suggestions on any deals right now on an Intel based mobo and cpu? Prefer one with a solid sata 3 controller for my Agility 3. I prefer the Intel cpu the be a quad core,doesn't have to be threaded i suppose as alot of games don't use over 4 threads?
Any deals including cpu/mobo/power supply/ddr3 and a case a plus also.
Im planning on reusing my video card and hard drives.
Edit** Bump for the hardware yoda's to chime in. Also i could bump the money spent to 600ish.
Begging here guys. I haven't been able to keep up on the cpu/mobo front in the past 1 year due to military. Looking for a cheap sandy bridge build with mobo/cpu/case/power/ram.Case can be cheap as possible. I just need the mobo to have native sata 6gbs for my agility 3 which ill be reusing along with my video card.
So you want to get a CPU and Motherboard for $500 - $600?
That's easy. Combo deals on Newegg can save you about $25. For about $470 you can get an Intel Core i5-2600k and a MSI P67A-GD65 motherboard. All H67/P67/Z68 mobos have Sata 3.0.
But if you want a CPU, mobo, PSU, and ram for that price range you'll have to go a little lower.
Figure $50 for 4 gigs of ram. The lowest cost PSU I'd recommend is around $35, the Antec Earthwatts.
Then figure that a Core i5 2500k is about $215. That's $300 so far. Most ATX mainboards are between $120 to $180 and will all have USB 3/Sata 3. That could put the total to as low $420 for a cpu, mobo, ram, and PSU. Obviously you'll want to get a more substantial PSU depending on your needs.
Stick with the i5 2500k or i7 2600k. The 2600k will add $100 on top of that, but I have a 2500k and I love it. Pair one with the Asus P8P67 LE for $129 and you'll be able to do whatever you want. The 2600k isn't really any faster than the 2600k when it comes to gaming. You didn't state what GPUs you'd be running, so you'll probably need to get a bigger PSU. If you can get everything else with money to spare, consider getting 8GB of ram. You can get an 8GB kit at Newegg for ~$70 depending.
That's pretty good deal. You could get all the stuff in there minus the case and it wouldn't save you any money. So its like you're getting the case free. In contast there's this:
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.661407
you'd save $20, but it has a god awful PSU and the $20 easily justifies the better Antec unit. Plus the combo I posted has a uATX board by Gigabyte, which could hinder your plans if they include more than one GPU or other cards, like sound or NIC/Wifi.
I like Jbort1984's better. The EarthWatts is a good PSU. It's on the high side of bronze efficiency and is robust. If you're not in the lower 48, shipping will be a bitch, but you'll have plenty of money left over if there's something else you want or need.
Happy hunting.
Those deals? No. But you can take advantage of other combo deals with individual items. For the first combo you save $55 I think buying all that stuff together. If you wanted to get all that stuff minus the HDD, you'd still pay about the same. All in all its a pretty good deal.
Let me ask you this: you say you don't need the HDD, but do you need the case? If you don't need or want either you could get the rest of the stuff for around $450.
If you ONLY want a PSU, CPU, RAM, and a mainboard, you could try getting two 2-item combos, like a RAM + MOBO and save $25 and a CPU + PSU combo to save like $20 for example. With similar items at similar prices to the whole system combo, you could get the $450ish dollars down to around $430 AND get 8GBs of ram.
8GB of ram is the sweet spot: 2x4GB kits are cheap on their own but I bought some G.Skill Ripjaws X 1867mhz 2x4GB for $80. I could have got some 1333 G.Skill sniper 8gb kits for only $60. So then, if you can find a combo deal for $20 off some combination of ram and one of the other items, you could get it even cheaper.
Post some more info and I can make some suggestions if you like. Just remember that if you;re planning on shopping at Newegg, their combo deals and sales come and go frequently so you'll do best if your flexible when it comes to purchases.
Well, you can swing it.
Newegg is going to sell 8GB of ram today as a Shell Shocker for $58, with free shipping.
