help me voltmod my nf7-s
-=iNsAnE=-
i have an nf7-s 2.0 and mushkin lvl 2 pc3500 with bh-5 and i wanna do the vdimm mod.. i have no soldering experience or with any kind of volt modding.. i konw there is a couple different ways to do this mod.. so i have a few questions
1.) does anyone have a good link that is very easy to follow that a newb could easily follow?
2.) could this mod fry my RAM? or if i mess up is it basically just gonna fry my mobo? i dont wanna loose my RAM or my mobo.. but i'd rather just loose a motherboard..
any help is greatly appreciated
ok that seems fairly simple.. i bought me a small point soldering iron and one of those resistors.. once i do the mod will the voltage my memory is running at show correctly in mbm?
Nope, not going to happen. You'll have to use a volt meter as explained in the guide. After that, just mentally add the difference between what your volt meter and your bios relates.
does anyone have a close up pic of their mod after it has been soldered? the guide is pointing to the right portion of the onboard resistor.. but does it matter if its on the right part or do i just solder the wire to the resistor anywhere? its so small i dont know if i could hit just a portion of it with solder
also, it doesnt say in the guide where to check your voltage.. where do i do that? (this is the vdimm mod, btw)
again.. that is not the memory voltage mod.. thats the chipset voltage mod.. those arent the check points for the memory voltage.. i did find the checkpoint for the vdimm mod on another site though.. as well as the answer to my other question.. hopefully i'll be able to get it now.. if my soldering skills are good enough.. thanks for all the help
