Help me upgrade
It is time to upgrade my video card. Current set up is i5 2500k ocd to 3.8ghz, Radeon 5850, 16gb ddr3. Is anything pretty much a upgrade at this point?
What is your budget, your country and your power supply ?
If you can't go beyond $200, get the R9 285 as it will stomp the 960 all over. You would need a GTX 970 to be a worthy nvidia card
If that's the case why does [H]'s GTX 960 review show it beating the 285 in every game except Tomb Raider where they tied ? The 285 lost to the GTX 960 in 2560 as well. There are valid reasons to go with the 285 but I fail to see where it stomps all over the GTX 960.
If i were you i would try to grab a used GTX 760 for around $130-$150 or even a used GTX 770 can be had for under $200 nowadays. Both cards offer excellent performance at 1080p
I've seen quite a few 290s for sale right around $200 on the forum here. This is what I would hold out for if I were you.
You do know that there are butt loads of 960 reviews right?
Along with that convenient chart posted above that shows the performance of the GTX 960 in relation to ALL OTHER CARDS YOU CAN BUY RIGHT NOW?
HIGHER RANKING = TEH MOAR FASTAR!
