Sorry this is probably dumb but I am so use to the physical server route.
Normally with physical servers I have a C Partition (usually a raid 1 array) and then a D Partition (usually Raid 5 or Raid 10).
Now I keep reading "putting the vm on this array and having a zfs array"
Now when I think of the VM I am thinking in my physical world the C and D Partition. When I am messing around with Hyper V at the office on a test server I have a Raid 1 Array which I have Server 2008 with the Roles installed, then I have a Raid 10 Array that I created a few guests. I went through the setup and create a 100GB Disk and installed OS 1, then created another, etc, etc.
So if you were to have a SAN or some shared storage, would you just create a Disk of X GB and then install the OS?
Then say you are doing Exchange server, do you install the OS and then where do you locate the data? Is it on the same virtual disk you created to install that OS?
Sorry these are probably noob questions but trying to get a grasp over the full thing.
