could you someone explain gpu readings and which one is the most important as far as your overall temp readings:
GPU temp
GPU Diode temp
GPU ambient temp.
I notice also that readings in riva tuner temp readings can be a few degrees higher than everest.
GPU temp
GPU Diode temp
GPU ambient temp.
