Running an eVGA X58 Classified E760. I'm trying to address the temps. I'm not sure if my voltages are too high or maybe my radiator fans need to be upgraded. I thought my temps should be better with watercooling.
If you have any suggestions on my setup, please let me know, otherwise what can I change in my bios?
Thanks
Setup
See signature
Water cooling
EK full coverage motherboard block
EK HF supreme cpu block
Black Ice GTX 480 radiator (4 x 120x25mm ~80cfm)
Swiftech MCP-655 pump
Swiftech MicroRes v2
Temps
Prime95: 82degC
Idle: 47degC
Bios Settings
Frequency Control CPU Clock Ratio ( 20X )
CPU Host Frequency (Mhz) ( 210 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( 4006 )
CPU Clock Skew ( 0 ps )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
Memory Feature Memory Speed ( Standard )
Memory Control Setting ( Enabled )
Memory Frequency ( 1333Mhz / 2:10 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 9 )
tRCD Setting ( 9 )
tRP Setting ( 9 )
tRAS Setting ( 24 )
tRFC Setting ( Auto )
Command Rate ( Auto )
Voltage Control EVGA VDroop Control ( Without VDroop )
CPU VCore ( 1.40625v )
CPU VTT Voltage ( +400mv )
CPU PLL VCore ( Auto ) 1.8
IOH PLL VCore ( Auto ) 1.8
QPI PLL VCore ( 1.2v )
DIMM Voltage ( 1.65v )
IOH VCore ( 1.250v )
IOH/ICH I/O Voltage ( 1.650v )
ICH VCore ( 1.250v )
NF200 Voltage ( Auto )
VTT PWM Frequency ( 250 KHZ )
CPU PWM Frequency ( 800 KHZ )
CPU Impedance ( Less )
QPI Signal Compensation ( Less )
CPU Feature Intel SpeedStep ( Disabled )
Turbo Mode Function ( Disabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( Auto )
Thanks
Setup
See signature
Water cooling
Temps
Prime95: 82degC
Idle: 47degC
Bios Settings
MCH Strap ( Auto )
tCL Setting ( 9 )
tRCD Setting ( 9 )
tRP Setting ( 9 )
tRAS Setting ( 24 )
