How it started:
Have old POS desktop with AGP slot. Also have a Dell 30" which i've been waiting to buy new pc to use it with. Received gift card for Best Buy (hate that place) so i thought i'd buy a modern AGP card for my old pc to hold me over until i can buy the new pc.
ISSUE:
Best Buy AGP card selection sucks. So i purchased an ATI 2600XT agp. Installed it, booted up, installed drivers....everything going good. Turned pc off to move it...turn back on, and no post. Swapped out card with old video card....it posts. Put new card back in, it posts! Shut down, turn back on, no post. So unless i want to turn it on once and leave it running forever, it just doesn't seem it's gonna work.
CAUSE:
my theory is my old mother board (which only has a 4x agp slot) is not handling the power the card is pulling? But is strange 'cause this 2600xt has a power connector on it (which i DID connect to psu) My PSU is newer...trupower 550...Antec i think?
RESOLUTION:
This is where i need help....i spent a long time swapping out the old and new and no matter what i did, it either would only post once, or not post at all. So i'm convinced the 2600xt won't work on my board...so i'm gonna return it.
Should i even bother to try another card? They have a Geforce 7600GS agp.....my only hope is that it wouldn't put the same strain on the motherboard that the 2600xt did. (if that's even the cause)
What should i do?
ISSUE:
CAUSE:
RESOLUTION:
What should i do?
