We're using CableOne.NET at my mom's house. She's got the 1/2 T1 account, allowing us to have up to 3 IP addresses accessing the cable connection via either a hub or a router. They allocate the IP addresses based on the number of unique MAC addresses online on the account at any given time.
In our case, we're using an Intel InBusiness 10bT hub. My mom's PC is a Win2k (SP4) box that is working fine. My brother's box is a WinXP Pro box (SP1) and it works fine.
So far along the way, everything has worked fine with just the two PCs. However, I brought my PC home for holiday and plugged it into the hub with the expectation of doing the simple CableOne.NET 'EULA Agreement Page' to register my MAC address and allocate an IP for my PC.
However, things have gone really awry. I plugged my PC in and booted it up. I open up IE and nothing. No IP address, nothing. It just reverted to the perenial 192.168.x.x address range.
I tried troubleshooting a few things on the PC related to NIC drivers and all, but nothing helped. In a last ditch effort, I plugged the PC directly into the cable modem (bypassing the hub) and voila it worked. Well, it's nice that it works that way, but defeats the purpose of the hub. However, while connected, I went ahead and did the EULA agreement in the hopes that maybe that will be my ticket. I connect it back to the hub and now it does something different.
Now, I get an IP address assigned, and I can telnet, SSH, and FTP from the command line, but I cannot access web pages via ANY browser (I've tried IE, Mozilla, Netscape, and Opera). When I try to load a web page, it says that it resolves the host, but it never loads the page.
Frustrated (and feeling like I suddenly need a re-install), I rip WinXP Pro off my box and install Win2k. Still nothing. Still troubleshooting, I go back to Win98. Nothing.
Thinking that somehow it's a Windows issue, I boot my Knoppix CD. Nothing. So, now I know that it's some bigger issue. Thinking it might be the NIC, I swap the NIC out. Same issue. Thinking now that it's the hub, I swap the hub out. Nothing. Getting desperate, I change out the ethernet cable. Nothing.
In all of these cases (including the retro Windows installs and the Knoppix boot), if I connect it directly to the Cable Modem it works.
So, now after many hours installing and re-installing, I'm back to WinXP Pro SP1 and curious as to what I should do now.
I've tried the WinSock XP fix and I've trimmed the networking stuff in XP as much as I can think to do.
I've also scanned for viruses with the latest Norton signatures and it turned up nothing.
Can anyone out there think of anything I've missed that I ought to try?
BTW, the normal NIC I use is an Intel Intelligent Server Adapter (the one with the i960 on board) and I swapped it with an EtherExpress Pro 100 B).
Thanks for any ideas.
