help me someone...
shade
ok, this is the first time i have attempted to take out a agp vcard. i was just curious. do u just pop it out like a regular pci card? just unscrew the screw and pull it out right? btw the only way u can hear a beepin noise is if the vcard is improperly placed in or power is not plugged in correct? i got a nf2 mobo...i just installed some ram now i get beeping from my vcard.
There could also possibly be a little clip at the end of the agp slot that you will need to push to the right as you're pulling the card out. Otherwise it will be just like pulling out a regular pci device, yes.
