Help me sleeve my PSU cables.
dat722
http://directron.com/ffr.html
I was planning on buying this to make the wiring inside of my computer a little cleaner. Is there anything wrong with this and/or is there a better sleeve anyone can recommend? Thanks, your opinion is appreciated.
Which one would you recommend/or use? There are so many different options.
