Help me set my bios :)
Vipex23
I have a MSI Neo2 K8N Platinum nForce3 Ultra MoBo and a AMD Athlon 3500+ New Castle processor with this ram:
CORSAIR XMS Xtreme Memory Speed Series, Xtra-Low Latency 184-Pin 1GB(512MBx2) DDR PC-3200 w/ Heat Spreader, Model TWINX1024-3200XL
Can you tell me what should be set in the bios?
Thanks.
Thanks.
What do you mean specfically? As in the memory timings? Until less then a month ago, I was using that motherboard and the same RAM (okay, XL-pro, but other then the LED heatspreaders same stuff), and found that if I ran at 2-2-2-5, I'd fail Memtest 86+. I had to run it at 2-3-2-5. I want to say that Mushkin suggested running memory, both their brand and other brands at one higher on the second memory timing number to ensure stability if using a Socket 939 board.
I think one had to set the AGP FSB to 67 or 68 to make sure the PCI/AGP lock was in place, but that may have been rumor. I still did it just to be sure, though.
As an aside, only the "upper" two SATA ports (ones next to the video card) are locked as far as the AGP bus is concerned, unless the corrected this the ones lower down on the board, even though running off the chipset for some reason are not.
Can you be more specific as to what you want/need? I think I remember this BIOS well enough, and still have the manual. Just sold the board to a friend, but have yet to install it in his system (believe me, one doesn't want to let my friend install it. ;) ), so if nothing else I'll be briefly looking in the BIOS again in a week or two. ;) But ask some specific stuff.
Maybe try this link for some BIOS definitions:
http://www.rojakpot.com/default.aspx?location=7&var1=18
Me
