Help me score points with my Girlfriend
RancidWAnnaRIot
EspantaPajaros
Okay, so my girlfriends brothers PSU fried, it also took the mobo with it. It was a pretty damn old celly... so now it's up to me to pick out cheap but decent parts.. here's what i need
PSU
Mobo (with integrated sound and video)
CPU
RAM
I'm gonna go with AMD cause cash is a big problem here.. I particularly want to see suggestions on mobo's that have integrated sound and video... also a decent PSU.. remember price is a big issue here.. i would appreciate the suggestions
Thanks
Crap.. could you also suggest micro ATX boards with the same criteria??? i'm not sure if it's a micro ATX i have to measure it.. though i'm pretty sure it is...
Also will a micro ATX fit in an ATX case? Do the screws line up?
Anyone know what are the dimensions for something to be Micro ATX?
Mobo:
http://www.newegg.com/app/ViewProductDesc.asp?description=13-127-159&depa=1
processor:
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-383&depa=1
PSU:
http://www.newegg.com/app/viewproductdesc.asp?description=17-103-481&DEPA=1
Just built a system with the Motherboard above for my mother-in-law. For web browsing, light image editing and word processing, it works fine.
One of these days you really need to research this stuff on your own. :)
As for your specific questions - MicroATX boards fit in ATX cases 99% of the time.
BB
